Chalo
100 TW
Hi y'all,
I have been building e-bikes since the '90s, but this is my first venture into lithium battery land. I am as baffled now as I was back then trying to decode Heinzmann motor specs.
Here's the context of my battery question: I'm electrifying a kick scooter for a dear friend of mine. I have salvaged a Wilderness Electric (Ri Chi) brushed hub motor from one of my early projects, and laced it into a 16" wheel. I have a couple of 36V brushed motor controllers in the 40A range that I can use. They are not programmable at all. I have lots of heavy cable and Powerpoles and solder, and plenty of experience putting these things to good use. But I want to get my friend set up with a reliable, not too expensive LiFePO4 battery that will play nicely with the rest of her system.
My friend went online and found various rechargeable tool batteries with predictably high prices, small capacities, and inflexible interfaces. I'm hoping I can do better than that.
I was looking at the LiFePO4 packs at HobbyKing, trying to figure out the simplest satisfactory arrangement for my friend, when it occurred to me that these controllers I have are intended for SLA batteries, and therefore they have a low voltage cutoff of about 29.5V or so. I don't know how deeply a LiFePO4 cell can be discharged, let alone a pack.
Ideally, I give my friend a system that does not require any close attention to a voltage readout, because she has other things to think about, and because she has adolescent kids who will use this thing. It would be ideal in this situation if the existing LVC could be matched to a LiFePo4 cell count that works for that value. I want to be as conservative with the discharge depth as necessary for long service life and reliability.
So here are my questions:
- What is the per-cell minimum voltage for LiFePO4? Does this number vary between different manufacturers' batteries?
- How much should I pad this value since I'll be using a pack of between 10 and 12 cells which must maintain balance?
- Does my existing 29.5V lo voltage cutoff correspond to an integral number of LiFePO4 cells?
- Can someone recommend a battery (or batteries) from HobbyKing or elsewhere? I'm looking for 4Ah or more.
- Can someone recommend a balancing charger from HobbyKing or elsewhere that would be a good match for this application?
Considering the objectives here-- long life, reliability, and brain-free operation-- is R/C LiFePO4 even a good idea? is there a better option?
Thanks for any insights from you knowledgeable folks.
Chalo
Chalo
