BMS terminal clarification
columbiajack
I need to swap out a bms because of bad fets. The new Bms has terminals marked the same as the old. The B- "negative battery". P- "negative battery output" and the white sence terminal locations I understand. The ones on the end marked B+ B+ P+ P+ I don't know what goes there. The only wire which would be a guess is the negative charger wire. The only other I don't know what to do with the red+ and black- wires that were on either end of the sence wire connector on my old bms. The new bms only has 11 sence wires
that schematic shows how to connect the sense wires. you do not have to bring the B+ lead over to the BMS using a large cable. instead you can use a small wire like the sense wires to connect B+ to the B+ spot on that BMS.
then connect the controller P+ directly to the battery at B+ with the large wire needed for the current.
Presently the B+ heavy out put is not connected to the bms. It comes out the pack to the main battery connection.
My confusion is where the Neg - charge wire is suppose to be connected on the new bms
And what do I do with the small red+ and black- that is currently on either end of my sence wire connector
Thank you for your input and patience. Jack
i explained how to wire it and there is a schematic in plain view. they use a red wire for the top and black for the bottom. if your BMS does not have a separate C- charging port then connect the charger negative to P- on the BMS. but only if there is no charging mosfet.
Sorry I don't see a schematic in plain view. I don't understand red wire for top and black for wire bottom. What is top and what is bottom?
How would I know if there is no charging mosfet? Then the only thing is if you look close in the second pic there is a red and black wire on either side of the sence wire connector. What do I do with them? My new bms dosen't have them only 11 white wires Thanks again
B+ is positive from the cell pack
B- is the negative from the cell pack
P- is the BMS negative to your controller
P+ is the BMS positive to the controller
B0 is the cell pack negative
B1, B2, B3, etc is the positive sense wire from each cell.
C- is the charge socket negative.
Different BMSs are wired differently and have different numbers of pins on the multipin connector, so you might have to change the wiring a bit. Not all BBSs use B0. Often, they have no B+ either.
Here's a general schematic that might help you understand it:
That diagram is great! I have 2x10S 4P Tumich batts to set up for a bms.
otherDoc
Thanks for the schematic. It would all fall into place if the new bms had a "C" charge terminal and if it showed what to do with the red + and black- wires on either side of the sence connector.
i already told you that if there is no C- spot on the BMS and it has no charging mosfet then you connect the charger negative to P- on the pcb. the red wire is the most positive sense wire and the black wire is the most negative sense wire. what else can i say?
Ok I understand to use the P- for the charge terminal
But what do I do with the red and black sence wires. The new bms only has 11 white wires. My old has 11 white and the red and black.
