moonshine
There's a little bit of laziness to this post, but I will honestly say that i have very little idea on how to setup bulk charging with a 70a coil
I'll be charging up at 20s8p samsung 25R pack. I guess my options are the bmsbattery bulk chargers or getting a set of meanwells from teslanv and wiring them in series. I get how i'm gonna need three wired in series to manage charging my pack...
What i don't understand is how to gauge what kind of psu is required if you are using the 70a charge coil. I've heard from sources...that I should get a psu lower than my battery voltage after full discharge (in this case 50V). How do you know how much extra voltage the 70a coil will provide? how do you titrate that voltage? Also, how does using a coil help/hurt charging? Faster charge times? Any insight and guidance on what to get what be greatly appreciated.
