Rectifier Huawei R4850G2 48V 42~58V 3000w
celioregoli   1 µW
Re: Rectifier Huawei R4850G2 48V 42~58V 3000w
Post by celioregoli » Feb 27 2021 6:50pm
Irling wrote:
Jan 26 2021 2:27am
Can you please tell me if I can use 3 modules 0-140 volts for serial connection? I need about 400 volts to charge the 96S battery.. I am worried that the diode bridge or output transistor may burn out :bolt:
we want to do the same thing, except that I have 225v 54s, the engineer tells me that it can be done with diodes in counterphase
the huawei to be able to reach 120v it takes a hardware modification, the switching frequency must be changed, they sell the kits on taobao, or already modified. so to make 400v you need 4 to 100v.
I believe that if you connect a charger every 24 cells, it is safer
frank_zero   1 mW
Post by frank_zero » Mar 20 2021 4:07pm
frank_zero wrote:
Sep 28 2020 1:58pm
aansluiting.jpgWhat is the type or connector for the start plug and the communcation , can plug ?
https://www.ebay.com/itm/5-Pair-2Pin-Ma ... Y7OMHgpr50
are the small connectors for the start and can bus connection
kleine stekkers.JPG (74.01 KiB) Viewed 1362 times
frank_zero   1 mW
Post by frank_zero » Mar 20 2021 4:12pm
rigmo wrote:
May 26 2020 3:14pm
IMG_2637rez.pngHI NEWS
Display monitoring of huawei and emerson PSU.
control boards
USB serial port cable
Huawei and Emerson's control board PCBA is the same, but not universal, the software communication protocol is different.
Rigo or some one els can you tell us how to connect those control boards >
aansluiting foto groot.jpg (95.03 KiB) Viewed 1359 times
frank_zero   1 mW
Post by frank_zero » Mar 20 2021 4:30pm
CHA_LY wrote:
Nov 14 2020 3:38pm
Hi all
I still waiting for some info how to permanently adjust the voltage of my R4850G2 to 50V using the chinese controller received on the meantime.
No info at all was supplied.
I know how to connect the board - but how to permanently adjust the voltage.
I do NOT want to change the curent limit.
Thanks
Charly
SEE
viewtopic.php?f=14&t=86038&start=25#p1441995
jairbj   1 mW
Post by jairbj » Jun 04 2021 9:02am
rigmo wrote:
May 26 2020 3:14pm
control boards
Hi friend, could you share the communication protocol for Emerson's PSU?
meelky   1 µW
Post by meelky » Jun 16 2021 5:27am
vasitse wrote:
Oct 03 2019 12:52am
rigmo wrote:
Feb 27 2019 5:28pm
I have direct contact of PCB controller builder from china.. 任星星
Hi! Can you provide details? Thank you!
meelky   1 µW
Post by meelky » Jun 16 2021 5:33am
Hi,
From where I can source these type of back plane PCB as attached?
Meelky
meelky@yahoo.com
djgrazzy   1 µW
Post by djgrazzy » Jun 27 2021 5:14am
meelky wrote:
Jun 16 2021 5:33am
Hi,
Meelky
meelky@yahoo.com
I noticed this mentioned the comments
https://www.ebay.co.uk/itm/163584839215
On this video
https://youtu.be/U9LE8FThbPU
rigmo   1 mW
Post by rigmo » Jul 17 2021 7:30am
Hi
Sorry for late reply
I have two pcb control boards for sale.
marast   1 µW
Post by marast » Jul 26 2021 10:04am
Please can anyone advise me what is the possibility of a serial connection of 2pcs?
Thanks, Mark.
frank_zero   1 mW
Post by frank_zero » Aug 24 2021 10:59am
Hello does any one have 1 or more controllers for sale ?
the can bus controller for the
many thanks Frank
you can send me a PM message.
can bus controller 1.jpg (95.03 KiB) Viewed 750 times
Silvaticus   10 W
Post by Silvaticus » Aug 24 2021 12:10pm
frank_zero wrote:
Aug 24 2021 10:59am
many thanks Frank
I would like to join to the request. Since I was having difficulty purchasing this item from TaoBao.
frank_zero   1 mW
Post by frank_zero » Aug 26 2021 11:05am
How to order a control board for can bus update 26 aug 2021
like the one in the picture
i made a account on
https://parcelup.com/
that is the old (https://tbfocus.com)
you can pay whit paypall '
or credit card
i then send a message to
https://parcelup.com/live-support/
can you please this item in my shopping basket:
https://market.m.taobao.com/app/idleFis ... 5948826876
1 or 2 days later they will send you email
can bus controller 1.jpg (95.03 KiB) Viewed 721 times
Silvaticus   10 W
Post by Silvaticus » Aug 26 2021 4:59pm
frank_zero wrote:
Aug 26 2021 11:05am
Thanks. I will try. It's just that when I was looking for an intermediary, none of them answered, and after reading the reviews that most of them communicate only until the moment of money transfer. After that, they may forget about you for a month. I then decided not to mess with them.
jairbj   1 mW
Post by jairbj » Aug 26 2021 8:47pm
Silvaticus wrote:
Aug 26 2021 4:59pm
frank_zero wrote:
Aug 26 2021 11:05am
I bought there using superbuy.com
Everything was done using their website. Their service plus shipping to Brazil had cost about U$ 25.
frank_zero   1 mW
Post by frank_zero » Aug 26 2021 11:13pm
I always have a good and fast communication whit
Taobao FOCUS Team
https://tbfocus.com
Taobao FOCUS Support [https://tbfocus.com/support]
but is only the 2e time im buying 2 of those can bus controllers.
1e time at the begin of this year.
Silvaticus   10 W
Post by Silvaticus » Aug 27 2021 8:04pm
Thank you guys again. The last time I ordered what I needed on Alibaba. Luckily it was found there.
JackFlorey   100 kW
Post by JackFlorey » Aug 30 2021 5:36pm
Hi all.
I have a 4850G2 here and working. (Programmed via CAN for my voltage and current, which is 54.6 volts and 20 amps.) However I notice that on startup it initially goes to maximum current (~26 amps at 120VAC in) before it backs off to 20 amps after about one second. I am worried that if I connect to 240 volts it will go to 56 amps and fry wiring and batteries.
Has anyone else seen this? Any ways around it? I could build some gadget to gradually ramp voltage up to 54.6 volts over 10 seconds or something but that seems like a lot of work.
Darren2018   100 W
Post by Darren2018 » Aug 30 2021 6:08pm
JackFlorey wrote:
Aug 30 2021 5:36pm
Hi all.
The R4850G2 generally overshoots by 5A, it's completely normal. If you disconnect the load and then immediately reconnect it the overshoot decreases. I first thought that it was the output capacitor voltage but it is always by 5A so obviously that isn't the reason. As long as the load is not too sensitive or fused I don't think it is a problem. Maybe someone with more experience can explain exactly why it does this?
JackFlorey   100 kW
Post by JackFlorey » Aug 30 2021 10:33pm
Darren2018 wrote:
Aug 30 2021 6:08pm
Does that suggest that if used at 240 volts it would still overshoot to 25A and not 56 amps? If so that's good news.
Darren2018   100 W
Post by Darren2018 » Sep 01 2021 4:04am
JackFlorey wrote:
Aug 30 2021 10:33pm
Darren2018 wrote:
Aug 30 2021 6:08pm
Yes.
JayKhan   100 µW
100 µW
Post by JayKhan » Oct 16 2021 12:50pm
HI everyone, just made an account, you guys discussed everything very nicely. thank you
I purchased few power supplies (Used ones at 14~15$ each) , searching on YouTube, I found one guy made induction heater power supply with this same power supply and then on google search I came here.
JayKhan   100 µW
100 µW
Post by JayKhan » Oct 16 2021 1:04pm
For voltage adjustment and current limit, I purchased that CANbus module from taobao via parcelup (Taobao FOCUS becomes Parcel Up) by following the same process which was shown in YouTube video. and received it in 10 days in Pakistan. total cost 37.4$ for 1 module (psu was 14$ and module 37$ lol)
close up.JPG (358.47 KiB) Viewed 836 times
purchase cost.JPG (28.67 KiB) Viewed 836 times
JayKhan   100 µW
100 µW
Post by JayKhan » Oct 16 2021 1:23pm
to connect CAN module and power switch, I added 6 pin JST connector on the free space of PSU.
JayKhan   100 µW
100 µW
Post by JayKhan » Oct 16 2021 1:30pm
Voltage adjustment and current limit tested with module. I have noticed few things, one is that PSU works best between 50-55v, other then that, at any voltage PSU fan spins really fast, i don't know why. (without any load)
no cc.JPG (285.79 KiB) Viewed 835 times
5a cc.JPG (241.49 KiB) Viewed 835 times
