Affordable spot welder for huge packs
rg12
Hey guys,
I'm looking for a pneumatic spot welder that can go very "deep" into the pack as I'm doing many 20S 18P packs
The spot welder head needs to go about 9-10 cells "deep"
I prefer it as one unit as the separated units with huge copper cables to the welding unit need much more current and trip the switch almost everywhere I tried.
https://malectrics.eu/product/diy-arduino-battery-spot-welder-prebuilt-kit-v3/
only needs a car battery and if you make your own cables from 16mil you can use 1M long cables.
i use this and have the unit and battery above the work area on a little shelf. i can weld basicaly up to 1.5M wide packs in a single go.
I got something like this but I need a professional machine with air pressure driving the head to push down at the tab
You can buy those from a few companies. I have contacted a couple in the past for this but pricing was not worth it. You are looking at 2k and up for the whole machine and 700+ for a single head assembly. Shipping and taxes added another 500 or so.
Right now i am just looking into something to cut the nickel to length for me. That takes up most of my time and causes hand strain so i likr to spend money there first.
How about something like this
https://www.ebay.com/itm/Y-Type-Nickel-Conductive-Plate-0-15-6-25-Mm-For-18650-Battery-500-Pieces-Lot/332674080886?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D52473%26meid%3Dc255cb66742f4a8c8509feb98f175a19%26pid%3D100005%26rk%3D5%26rkt%3D5%26sd%3D252952906089%26itm%3D332674080886&_trksid=p2047675.c100005.m1851
https://www.aliexpress.com/item/500pcs-0-2x30x8mm-H-type-Nickel-Plated-Steel-Strap-Strip-Sheets-for-battery-spot-welding-machine/32352134818.html?spm=2114.search0104.3.127.81ff14a6Oa2W44&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10151_10065_10344_10068_10547_10342_10343_10340_10548_10341_10696_10084_10083_10618_10304_10307_10820_10821_10302_10059_306_100031_10103_10624_10623_10622_10621_10620,searchweb201603_30,ppcSwitch_5&algo_expid=0b57418a-bc4c-439c-8da5-285f8f22ac9a-18&algo_pvid=0b57418a-bc4c-439c-8da5-285f8f22ac9a&transAbTest=ae803_2&priceBeautifyAB=0
There you go:
https://www.aliexpress.com/item/Aut...c60d-49ab-a83b-a9a407213c17&priceBeautifyAB=0
As for me I guess I will go with this one and extend the head with longer CNC'd copper nose:
https://www.aliexpress.com/item/1pc...2b3d-4d5b-8992-49cd0ec1243a&priceBeautifyAB=0
Thanks a lot for the link! The full bundle (missing just the car battery) costs only €118,80 shipping to Russia included!!! Just googled and found that a 60Ah/530CCA battery costs €46 in my city. It would be more than enough. So the total cost is €165 (or less) for an off-grid spot welder! I'm don't know if there are any cheaper off-grid battery-powered options but this one looks very good to me! Thanks again!
Making the cables longer than one meter (1/2M each, 1M total combined length) can add significant inductance to the system.
I think it's possible to attach the spot-welder onto an elevated "table" that allows the battery pack to slide under it. Doing that not only keeps you from needing longer cables, they can then be VERY short.
I use 16mil cables of 1m each and have no problems welding 0.2 strips.
Heating of the electrodes is a much bigger problem then the inductance.
Alan B said:
The inductance stresses and blows out parts.
that is why i got a spare. :wink:
