8C and 12C cells with same IR
rg12
Hey guys,
I have brand new Samsung 25R cells (about 1 year old stock according to the codes) and also Sony VTC5 cells with the same MFG as the 25R.
Tested the internal resistance with a tester and both show 8.2ohm
Is there something I'm missing? because the 25R is rated for 8C and the VTC5 at 12C
Did you cycle them at all?
I had some cells that had to be pulsed a few times at high currents, to get the IR close to new.
Internal resistance can be lowered after use? I thought its the opposite
Well after they sit a year the IR will be higher than normal. I once built a pack of Sanyo 18650 GA's.
On the first charge the cells got quite warm(almost HOT!), but after letting them cool the IR of the pack went down quite a bit. It never got warm after that.
Of course, this is not the same as high IR after 1000 cycles or over/under discharge.
but both are about a year old...so it should maybe stay relative and still the 12C should have lower resistance...
Just googled it an it seems that most rate it as a 20A cell (8C) so I guess there's my answer..
rg12 said:
Hey guys,
Is there something I'm missing? because the 25R is rated for 8C and the VTC5 at 12Cz
If 8.2 ohm was really the result for both cells,..then yes, you have a measuring problem !
Neither of those cells should measure more than 0.05 ohm ..!
What internal resistance tester do you use? I'm looking for one, but can't seem to find a good one that lasts.
Thanks for your reply! I'll try to find that from someone who will ship to my location. :thumb:
I have one of these testers (YR1035) and it uses an internal 18650 cell vs a 9V:
https://www.aliexpress.com/item/4001288864976.html?spm=a2g0o.productlist.0.0.457f312dsYEJMr&algo_pvid=2acd3f13-7045-49f4-afb4-60f992930792&algo_exp_id=2acd3f13-7045-49f4-afb4-60f992930792-2&pdp_ext_f=%7B%22sku_id%22%3A%2212000025616979301%22%7D
I think it is better all around than that yellow SM8124A unit
