Queen Battery QB18650 3000mAh - real high capacity at low price
thunderheart
Armenia
Original article: https://www.thunderheartreviews.com/2019/02/queen-battery-qb18650-3000mah-real-high.html
This is Queen Battery's second model in 18650 size and it's rated at 3000mAh. It's a low-drain (6.4A) cell with modest price tag so it could be ideal for using in battery packs.
The battery was bought from Queen Battery which is my reliable supplier of genuine cells and tested with ZKETECH EBC-A20 and a self-made battery holder. It's a PC-connected battery tester supporting 4-wire measuring and discharging at up to 20A.
I've used version 3.0 of my battery holder based on 0.5mm thick pure copper terminals
I've followed all the prescriptions of the IEC61960-2003 standard concerning battery's capacity measurement. Before each discharging cycle the battery was charged at standard charge current mentioned in its datasheet to charge end voltage. Before each discharging or charging i've held a 1-1.5hr pause. The environment temperature was 23.0-24.5°C. To be sure in results i've done each test minimum twice (usually 3-4 times).
The cell's heat shrink tube shows brief specs but has no data about production date or batch number. It shows "3000mAh" mention next to the QB logo.
The main specifications from Queen Battery QB18650-3000's datasheet:
Typical capacity: 3200mAh
Minimum capacity: 3000mAh
Nominal voltage: 3.7V
Standard charge current: 1.6A (0.5C)
Max charge current: 3.2A (1C)
Charge end voltage: 4.20V
Max continuous discharge current: 6.4A (2C)
Discharge cut-off voltage: 2.5V
AC impedance at 1KHz: ≤40mΩ
Weight: 47g
Measured initial DC IR at 3.2A in fully charged condition was 33.1±1mΩ
Measured weight of the tested cell was 46.15g
QB18650 3000mAh capacity test results:
The second 18650 cell from Queen Battery is designed to be discharged down to 2.5V not 2.75V like the 2600mAh one. At 0.2C capacity is slightly higher than 3000mAh. At 6.4A which is declared as its maximum discharge rate its capacity remains close to 2900mAh and the curve doesn't seem to have any signs of being close to the edge. I think the cell can handle higher discharge rates but i would not recommend to go over 5A in order to keep the cycle life in reasonable range.
High capacity and low price are the pros of QB18650-3000 but bear in mind that it's not a high drain cell. For applications like e-cigs or power tools it's not a good choice, but in a large battery pack with many cells in parallel groups it would be just in place.
Here is the video version of this review:
Check out my YouTube channel for batteries, chargers and other stuff reviews.
I've launched my blog where you can find all my reviews in one place. Every new test/review will be first published on YouTube and in the blog. I'll be happy to see new subscribers, comments, suggestions and just your thoughts.
That's around twice the internal resistance as a Samsung 30Q. :(
The QB is closer in power output to the ultra putzy 3.4ah cells, but without the capacity.
What's the price difference between a 30Q and this?
Thank you for doing the testing. Do you need to keep separate two ground wires and the two pos wires or two more alligator clips for a four wire connection ?
Why do you never mention the prices?
That's really the only argument for these cells so we'll need prices.
I don't think he has changed his test rig yet.
It's still the same 2 wire setup with the sens wires going to the clips and therefore measuring voltage drop between the clips and copper plates and also battery terminals to the plates.
The sag can be pretty extensive during high current tests at randomly bad surface connection.
But I would like to congratulate thunderheart on performing these tests. Strong good work.
Keep up the pace and set the bars high.
SlowCo said:
Seems a nice choice but what is the price per cell?
dustNbone said:
I don't sell batteries, i just test them. Last year i bought 40 cells for $1.4/cell as a part of a bigger order. They usually sell 200 or more cells at a time, so i don't think it's an actual price. Ask QB for an actual pricelist.
I didn't change it but i have made a modified BF-2A fixture sent to me by Docware. The only problem resting is to find a way to attach copper terminals in a reliable way.
For europe, ncr18650pf are still the best value for money it seems... Surprising after 5 years!
https://www.nkon.nl/rechargeable/18650-size/panasonic-ncr18650pf-3-7v-2900mah.html
Third best in value for the 2900mA class I suppose.
#1: https://www.nkon.nl/rechargeable/18650-size/samsung-inr18650-29e-2900mah-e6.html
#2: https://www.nkon.nl/rechargeable/18650-size/samsung-inr18650-29e.html
#3: https://www.nkon.nl/rechargeable/18650-size/panasonic-ncr18650pf-3-7v-2900mah.html
You could simply solder all measurement wires directly to the copper plates.
By that you get rid of the most prominent cause of sag as the highest resistance would be between the tiny clip teeth and copper plate.
~$3/cell?
