This is long winded and rambling so ignore it if you don't have time and patience .
Sorry, my communication skills aren't the best. I have a hard time expressing what I am really wanting to say.
I didn't want to ask ; is 30Q better than Sanyo NSX or GA because then I get answers biased toward those 3 cells . I should have asked ; what are the best cells at 7ish amps continuous for a balance of cell life and output? Because I was then more likely to get a broader range of suggestions and maybe something I was unaware of or hadn't considered. I realize the greater amount of parallels you have reduces the amp load for each added P cell , but each connection adds to the overall resistance of the pack . That and the quality of the connections, so that's why I focused on individual cell performance. Price matters , but longevity and performance are the top two criteria . I know lithium phosphate is a no brainer for long cycle life, but price becomes more of an issue there.
I can build a 36s5P of 30Q for $212.50 from IMRbatteries. That gives me around 15AH or 75amps overall . After looking at this test ( https://lygte-info.dk/review/batteries2012/Samsung%20INR18650-30Q%203000mAh%20%28Pink%29%20UK.html ) ,going by rated max continuous amp drain , this battery chugs along around 10 minutes per cell runtime at 100% DoD(4.2v->2.8v ) @15A . At that amp rate , it looks like a 5p string would have around 13.25 AH . It would also be nudging 50°c . I know the completed pack's resistance, temperature ,chemistry quirks and my vehicle's variables will affect the overall results , but I am just comparing the results per cell by this one test before considering those outside influences.
https://www.imrbatteries.com/samsung-30q-18650-3000mah-15a-flat-top-battery/
Now in the same scenario , the NSX ( https://lygte-info.dk/review/batteries2012/Sanyo%20UR18650NSX%202600mAh%20(Red)%20UK.html) runs for 8-9 minutes at the same 15a rate , but is at around 28°c when the test is stopped. I realize that the rated capacity is higher on the 30q , but that's a major difference in operating temp . A pretty smart guy that happened to be the key in inventing NMC chemistry has stated that temperature is probably the most important factor in cycle life . A comparable pack of those 36s6p would cost $210 plus have a few more AH . 2300x6 = 13.8AH (@15a) https://www.imrbatteries.com/sanyo-ur18650nsx-2600mah-20a-flat-top-battery/
The NCR18650GA results are : @15a the test was stopped short due to over temperature limit. I was almost sold on this battery in the beginning until I saw this . Considering I won't be draining 15amps per cell , I looked at the temp @7a and it was around 30-32°c , which is fine obviously, but that is at 7 amps. The NSX is operating in that temp range at 15-20a ! hrm.... So back to the original point of this post; clearly the GA is perfectly capable of handling 7a continuous , as are several other batteries, but wouldn't a battery that doesn't break a sweat at 20amps be more likely to last longer than one that can't stay in a safe temperature at 15 ? That was basically why I was insisting on the 10amp parameter . Is it cut and dry , that for my uses, the UR18650NSX the best option? Or are there factors relative to individual cells that I'm not seeing? I don't want a 20 or 21AH pack that falls on it's face in 300 cycles or sags hard on anything over 5amps when I could get 800 from a 13.8 AH pack that doesn't lose 20% of it's capacity in the first 200 cycles . Sorry for the long winded babble . Basically , for a 60lb/27kg machine without battery , what are the best options for a 35 amp controller , 36 volt/15AH or so ,150lb rider, mostly level pavement riding, 32cm x 17cm battery box , and under $275 USD total . I want to build it myself or come from a reputable source in the US so I won't have expensive shipping issues if it shows up DoA . I've had the suggestions of prismatic pouches (which sound like good options) , 25R , 30Q, UR18650NSX,HG2, MJ1 and HE2. Those all look like great options. Is there a best for my envelope , or just choose any one of those because they're all equally capable ? (yes I am mentally ill and borderline obsessive over hair splitting details)
