612wh or greater batteries for Haibike/Sduro/Yamaha X94 systems.
uhoh7
Unobtainium in USA currently (please correct). 500wh is way overpriced. Meanwhile 612wh and greater batteries for other systems are easy to find at 1/5 Yamaha cost.
The yamaha x94 system batteries are 3 prong and require a special 5v input in addition to the pos/neg wires, so you can't use one of the many 36v 612wh+ aftermarket batteries now available in the USA for cheap.
In germany guys are finding solutions:
https://endless-sphere.com/forums/viewtopic.php?f=14&t=70198#p1302126
https://www.pedelecforum.de/forum/index.php?threads/yamaha-reverse-engineering.39480/page-6
And batteries can be ordered from China (5 piece minimum) which are apparently ready to go.
http://www.pro-greenergy.com/product-detail/36v-haibike-battery-replacement/
I'm looking to find a 612wh or greater battery for my 2016 Haibike all Mtn Plus, and wonder if there are others also interested, or who have found a solution already.
Thanks for thoughts and suggestions,
Charlie
One solution is to take an existing battery, and parallel more cells to each group in it. Won't likely fit in the original case, though.
