eCruiser3k
- Joined
- May 4, 2019
- Messages
- 22
Hi everyone
First time I write here and the reason is that I cant find solution my variable regen problem. Im building ebike with new sabvoton 72150 controller and in the controller is 3 wire connector for variable regen. I also have brake levers which are between ground and "brake 0v" wire in the controller.
If I bring throttle signal to variable regen connector, nothing happen (I use my acceleration throttle with switch that I cut acceleration signal and move that to variable regen connector). I also tried variable resistor in the connector and that caused vibration when accelerate but variable regen did not working.
I use Bluetooth app for settings conficuration. I have tried to "e brake" and "regen" active and inactive.
If somebody can give me tips what else to try I would be very grateful.
Things what I dont know:
-Do I need pc software for variable regen?
-What is "high brake" wire? I dont have that but I have single "brake 12v" wire.
