Kuppenhorst
- Joined
- May 28, 2019
- Messages
- 27
Hi,
I have a problem with my latest build.
Here's the setup :
26" mtb basis
52v 30ah triangle battery
48v 1000w rated rear hub motor
11A/22A max square wave controller
LCD3 Display
Pas and thumb throttle
Pas is always on and I'm pedaling all the time
Throttle is only for starting and crossing roads etc.
I live in the Netherlands and we ain't got steep hills here.
I had everything running fine but then I decided to go with a more powerful kt sine wave controller 15A/30A max.
The new controller run smoothly and works just fine until it's getting warm and than hot.
The problem is when the motor /controller cuts off. When I switch off and switch on again everything works again. The lower the pas level the quicker the cut off comes. When I use throttle the whole time there's no problem. The same goes for pas level 5. Using the max current the controller won't cut off. Btw the motor runs smooth and silent, so I don't think it's the motor phases.
May be I need to change a display setting because I'm using a sine wave now? May be someone can point me in the right direction.
Here's the setup :
26" mtb basis
LCD3 Display
