I'm just about done converting ebike to new frame and I was test riding and the controller shut off I was at a lowish speed and went full throttle and it turned off, I lost all power and the cycle analyst dropped in voltage and shut off, I was just outside my house so I wheeled it in and tested my battery it shows 52.2v what it was before it turned off, and plugged it back in and it turned on, I jumped back on and noticed it seemed to sag in power, like 50% or more, I then wheeled it back in and sat the rear wheel up and tried to throttle, nothing, I span the wheel and the cycle analyst read the speed out and when I try spin and throttle it jerks
Rear mxus 3k hub motor
Em3ev 18fet controller
48v 59amp continuous battery
Let me know if you need more info
