I was out riding my newly converted e-bike with a 1500w Amazon rear hubmotor kit. It was running really well, until it came to a grinding halt. I was barely able to walk the bike home as there was a tremendous resistance int he hubmotor. I disconnected the controller and tried to turn the rear wheel. I was barely able to move it. My first thought was a seized bearing. I removed one cover plate and checked the sprocket side bearing. It was ok. I then checked the wire-side bearing. Also OK. I then checked the phase wires for damage and continuity. All good. The rotor appears to be magnetically locked in the stator. I was able to remove it with a lot of pushing. The magnets seem good and there is no sign of burning.
I then cut the phase wires at the solder connection to the wiring harness. Still no movement. I re-assembled the motor and it is nearly impossible to turn.
I'm worried that the motor is shorted in the coils. Can you point me in the right direction to attack this? I have a new hub-motor coming as a spare, but I would like to fix this one if I can.
