Alternative to Chinese Handlebar 3-way Switches
hias9
I have these two 3-way switches on the handlebar.
These Chinese switches work, but I don't like how they look on a bicycle.
Are there any alternatives? They should be water-protected and mounted on the handlebar. Nice if they would require less space than those two.
I don't know their specifics, but this
https://www.google.com/search?newwindow=1&q=3-way+switches+on+the+handlebar&tbm=isch&source=univ
shows a few that look different; maybe one of them will do better?
If you want to make something custom, then any 3 position on-off-on switch will work, like mini-toggle switches.
Ideal would be two waterproof 3way mini toggle switches on a bicycle handle bar mount.
Any ideas how to make this?
I am actually thinking about buying a 3D printer :D
Do you print them in ABS or PLA?
ABS is trickier to print but will hold up better outside. Especially from heat. PLA would probably be ok outside if it was a lighter color and not contained within a box where heat could build up.
This us what I'm using. Each switch is On - Off - On. I use these for high and low beam and on/off for the 12v subsystem. So I'm only using five of the six positions.
https://www.amazon.com/gp/product/B06X972V6X/ref=ppx_yo_dt_b_asin_title_o05_s01?ie=UTF8&psc=1
