Hello everybody,
I need your help. I recently bought a used and not working Super 73 SG. It had a code error 30 and the guy changed the controller but it did nothing.
I found misconnection in the harness, did some soldering and the code 30 dissapeared, but the pedal assist won't work. To make easier for you, here's what i know :
- Battery is good
- Motor works on "walking" mode (bottom arrow on the SW102 LCD)
-LCD works (on/off/lights/up and down button... walking mode)
I think the problem comes from the cadence sensor clipped in the bottom bracket. There is a LED but it does not work. Also the cable has 3 pins but the cable coming from the controller has 6 (higo without misconnections). There some voltage coming from the controller (10v or 4v).
Is it possible that the new controller was designed for a torque sensor? The bike is 1 year old and the controller is July 2019
What do you think?
- Battery is good
What do you think?
