1-4 extension cable pinout diagram required
phanivyas
Hi,
Does anyone know pinout info for 8pin extension cable used to connect Display,Throttle & Brakes to the Controller?
I am already using KT LCD3 & Throttle with normal JST connectors with my existing controller. I'm planning to swap the controller to that integrated one and want to interface existing parts to it.
Cable:
https://www.aliexpress.com/item/329...9.0&pvid=ecbcc39d-d2f1-4ae0-ae75-3e88477bd36a
Controller:
https://www.aliexpress.com/item/329...9.0&pvid=28dba476-af56-480a-a7f6-18592b36e4f2
Looks like this might be the one but I want to know which wire goes to Display & Throttle.
I found this I'm searching for the same solution I just want the display wires from the 8pin the rest of the new controller is the same as my old one .
