ax_foley
- Joined
- Nov 14, 2019
- Messages
- 3
Hey everyone,
I've been searching through ES for some months now picking up tips and generally excellent advice. I've built 2 ebikes over the past 7 months and had much troubleshooting along the way which 95% of the time, I've researched and solved the issues myself. The other 5%, I've reached out to the Ebike community and managed to get going again..
So I purchased a CA DP v3 direct from Grin. I took delivery a week ago and managed to clock up 50 miles so far. All working well with some tuning here and there to suit my needs. During a commute on Tuesday, my CA speedo started showing low mph 3 - 5 or so for about 10 seconds and then went to 0mph and has stayed there ever since. So as you can imagine I'm very dissapointed
I've checked the wiring to the controller and all seems okay. Everything is working as expected, PAS, throttle etc so i've no reason to expect an issue with the controller. I also had this delivered 2 weeks ago. I've reset the CA to it's defaults and this has not fixed it. This evening I took the back off the CA and checked the yellow wire had not disconnected and it hadn't. I checked continuity from the yellow solder pad on the CA circuit board to the end of the plug and this is okay also..
I emailed Grin on Tuesday evening but I guess they're busy as I've not had a response.
I really like the CA and this will not stop me using it but as you can imagine I'm quite dissapointed.
Any help would be really appreciated.
All best
Paul.
All best
Paul.
