Hello
I have an issue with the P1-Parameter and cant seem to find a solution for it.
I have a working Toprun TPH-B(A1)24R that has 16 Magnets aswell as a S06P Torquesimulation controller since i cant access the Hallsensors inside the Toprun. The motor had a integrated controller which died internally.
The motor works and spins correctly, the speed readout works without an external sensor too, but its not correct and shows a slower speed than actually driven.
I tried to set the P1 Parameter to 16 how i assume it should be, but it wont save the value. It always jumps back to 20.
Is there any remedy apart from using a reed based speed sensor?
Are those opensource firmwares a big help on that regard, are they even recommended to work around the parameter issues?
