skeetab5780 said:
Balmorhea said:
It looks like the gas and oil are going to leak out when you do that.
Nope! Just my right hand grip fills up with dirt!
EDIT: I just bought one of these slow dirt bike looking objects...Why? I don't know, i guess i've been mid drive for a few years now and i miss the hub motors
This bike is so bad its not even funny, I bought a used broken one from the Ebay vendor out of CA. I paid via Paypal like half price for it the vendor stated it had a controller issue...
I'm thinking swap the controller out and be ready to ride, but the second I start doing testing I find out the hub motor has shorted phase windings...I remove the heavy ass rear wheel and pull the motor apart and it smells like KFC Mmmmmm!!
The controller is a 72v 40a I think sine wave with a SW900 display which is pretty nice, at first I thought it has a blown Mosfet so I took it apart to inspect and it looked perfect with some pretty beefy copper trace lines on the PCB
The battery is a fairly weak 72v 18ah (it claims) I have not been able to actually test the capacity yet, but I did use this battery temporarily on my Denzel 4-spd Dirt bike. The battery worked OK but cut out fairly soon with the weight and current of the Denzel bike. I imagine it has a 30a BMS in it with 18650 generic cells
The charger looks fairly nice and seems to work fine, the vendor stated they do not know if the bike or charger works since the end of the charger cord was cutoff with just wires hanging out, I simply soldered on a DC connector and it works fine
The rear shock on the bike is a complete crap pogo stick, it says warning nitrogen filled blah blah but it does not do anything to a huge adult rider, this thing is sized similar to a 110cc pit bike and with a weak pogo shock its designed for a 10 to 15 year old rider. The shock is about 210-220mm long so I will be replacing it. I may try to one off my DB 17 Tao Tao since it is wicked stiff and I love the feel of it, but its only 180-190mm and I do not want to sacrifice the height loss
The plastics and the fake gas tank are all put on the bike makeshift and half assed, whole rear plastics/seat held on by two tek screws, plastic gas tank had one broken mount hole
The foot pegs are cheap plastic folding bike pedals and are pretty bad, one mount is slightly bend and they also do not even thread in all the way...
The kickstand is also pretty bad, its supposed to spring back automatically when you lift the bike up, but it barely functions properly
The rear swingarm i'm pretty sure has zero bushings or bearing in it, its likely metal on metal bolted together with a long thru bolt, it seems fairly stable while riding around but if you lift the ass end up to move the bike its sort of clunky and scary
The headlight assembly that I took off the bike and put on my Denzel dirt bike one of the blinkers does not blink or light up
The selector switch on the SW900 display had a broken plastic mount that needs repair
The SW900 has 5 different modes, and I doubt they all do something different
0 pedal assist mode draws like 3000w and cuts off the motor every few seconds if throttle is held pinned
1 mode says eco
2 mode says eco
3 mode says eco
4 mode says power draws like 4000w
after ripping the bike apart and seeing all these things wrong with the bike I reached out to the vendor and asked if he could refund me money for a new motor which I told him would be a very hard task to replace, they agreed and refunded me $200 back to my Paypal account
I then searched on Ebay and found the exact same motor that was on this bike, I took about a week before I clicked "Buy It Now" because I wanted to make sure it would be as easy as possible of a swap since it has moto hydraulic brakes and a moto wheel laced really tightly with not alot of room for error
The motor came in over the winter and I was putting off lacing the new motor into the moto rim for months. Just recently I googled a really easy website with like 5 pictures of a guy assembling/lacing old motorcycle wheels, I read the first few paragraphs and easily assembled the wheel going off his pictures as a guideline
Once that was done I put the laced motor back on the bike frame with the bike up side down so I could spend a few days spinning/ truing the wheel to my liking, I am no pro at this so I took my sweet time until I was happy with the results
The tires are also very heavy junk, the sidewalls below the bead of the tires had in excess of over an inch of rubber and I had to almost ruin the rim to get it off, I cut off all this excess rubber to help get the tire back on and to balance it out better. I had to replace the inner tube which was punctured trying to remove the tire that is how tight it was on, after lacing the new motor it took me two days to get the tire back on without hurting anything else or puncturing the new tube
Now just yesterday I finally was able to get the bike out for its first test ride, one thing I must say which I am not used to is that the bike is completely silent, it doesn't make any noise at all! I even drive my Vector Lite bike with a 9x7 Ebay stamped steel hub motor and even that bike wines and makes weird noises with the old Lyen controller especially during takeoffs, but no this bike is silent
The brakes are not too bad, look like single piston hydraulic pit bike brakes, pretty hefty and stop decent
The front forks are pit bike ish and are inverted with not a ton of travel, but they are stiff enough that I will continue to use them, the front end of this bike does seem pretty heavy since this bike will never wheelie on its own power even though it will likely get up to speeds of 35-40mph on flats
I am still not sure weather I want to sell this to some young rich kid on craigslist who will cherish it, or try to upgrade the pogo spring and add it to ever growing collection of ebikes
I can say one thing, all of the cheezy dirt bike plastics will not stay on the bike if I continue to ride it, I already have plans to put a Voloci seat on the bike since they are sleek and comfortable and a great design
