Hello, I have a Monster Moto electric mini bike (model MM-E1000). This is not an electric bike – it's a beefy electric mini bike (all battery powered, no human power). This machine has never really worked properly as it intermittently blows fuses and eventually destroys the controllers. I'm trying to decide if it's worth putting any further effort into trying to fix or if I should just give up on it. The manufacturer is out of business, so no help available from them any longer. People have posted similar problems to mine on reviews of this machine, so I know I'm not the only one, but some people have also posted solid reviews of the machine, indicating that not all machines have the same problem.
The problems I have had are mostly centered around this thing constantly blowing the 30amp blade fuse, and then occasionally blowing the controller (I'm on my 3rd controller, and have also replaced the wiring to the battery and the blade fuse holder). I've had it running "well" twice, and it has lasted for maybe 5-10 hours of use over a few weeks each time, and then the fuses start popping, and eventually the controller blows. The metal female connectors in the holder for the blade fuse has also melted once. So the root cause is not super obvious - it's one of those frustrating problems that doesn't have an easily repeatable pattern that can be used to troubleshoot.
Here are the rough specs:
The setup is pretty typical of an electric bike – see the diagram below for rough schematics of the key pieces.
Where I could really use some help is trying to troubleshoot the root cause of these problem. I'm no electronics guru, so learning as I go, but at the most basic level it seems that there is a mismatch between the power supplied and the capability of the internals to handle the requested load.
I've spent many hours trying to figure out how to get this running again and what component could be the root cause of the issues. Here's my best guesses as to what components could be at the root of the problems – what am I missing?
I know that's alot of info, perhaps too much to digest But thanks in advance to anyone who has the patience to read this and provide thoughts - much appreciated!
- 36v, 1000 watt motor
- 3x 12v, 14ah lead acid battery pack
- Poor quality controller (undersized wiring, resistors, etc.). I could get a different brand of 36v controller, but I know other people with this same equipment have not had my problems.
- Faulty motor – is it possible that the 1000w motor could be bad? Maybe it's occasionally drawing more current than the controller can handle?
- Batteries? What's the likelihood that bad batteries are to blame for this? I've measured the at-rest voltage and it seems fine.
- Throttle – Is it possible that the throttle occasionally calls for more current than the internals can handle? The throttle has three connections - "to put", "indicator", and "power locks". The throttle itself has an on/off button, a twist grip and a batter level indicator.
