Hello all,
I was hoping someone could provide me a little insight into some limitations I am having. I have a 72v 48AH Battery paired with a Sabvoton 72150 (software unlocked) controller, Cycle analyst V3 and a Qs273 Motor. I am unable to pull more than 80 amps from the Battery (it seems). I have checked all of the parameter settings to make sure nothing was limiting the current on the controller software and the cycle analyst. Because I am capped at 80 amps current it makes my think that the BMS is the limiting factor. The bike was sold to me as something that could Phase at 12kw power. Given my voltage I would need to pull closer to 150 amps to achieve those numbers. Is there a way to check the BMS limitations without opening up the battery so I can make sure that isn't the issue? I highly doubt the BMS is capped at 80Amps current but I wanted to rule it out as the suspect. I am able to travel at 55mph on dead flat but the CA3 is reading correctly at just above 5KW
If there is something you think that is limiting me other than the BMS by all means call me out on my Noobness.
In advance I appreciate you and this forum very much.
