Hi,
I have a basic conversion kit (originally bought 2016) that consists of a controller rated at 36V/7A for the small 250w hub motor I have in my front wheel. I looked around and googled it of course and it is likely a bafang 8fun. So start of this year I got a new battery and found it runs a lot better and picks up a lot faster. The new battery (also 36v) has a continuous output of 15A, the old one says 10A max. discharge on it. I assume the old battery was fairly worn, because it would be at 2/3 LEDs showing charge even when "full". The new one lights up properly as full.
Now my questions;
1.Does the controller limit my power or is the rating on the housing only a recommendation? So is it actually running on what the battery can deliver or am I now just back on the "full potential", being 250w at 7A? I saw that the battery charge LEDs only go off voltage so it doesn't show how much power it actually uses. Not sure what that means, because I don't think it's even drawing the 15A it could, given that the controller says 7A on it; if that's "fixed" I should be at 250w, is that correct?
2.Now since the new battery could handle a lot more output, would it be safe to run the motor with a 500w controller? I found one rated at 36v/500w/14A. The motor says 250w on it. If I use said controller would the motor a)still limit and run on 250w b)get damaged or would it actually have more power/faster pick up (being reliable and safe of course)? I read a lot about people overvolting motors and most only talk about top speed but I would still be on 36v with double the wattage, and I pretty much only care about acceleration on this.
Most I found about going 500w on a small motor use 48v and I would like to stay on the 36v and increase the power just by replacing the controller.
Im really curios as to what more knowledgeable people would advise going for.
Thanks in advance
Now my questions;
Thanks in advance
