Dear members,
I built an ebike with Mxus 3k turbo 3T motor, and Risunmotor 80A sine wave controller, this: https://m.aliexpress.com/item/328712396 ... sitedetail
I have a performance issue with it, not accelerating as good as i expected.
The display shows only max. 2300W power consuption when fully throttle acceleration. Battery amps around only 40A. My bat capable continuous 100A, (60V).
I tried tune with pc software, but this is the max wattage i can pull it.
Attached my basic setup.
When i set rated phase current to 80-100A, it not accelerate as fast with 150A.
But it should use max phase current when full throttle, right?
It is like it not use boost currents and limiting the rated phase current. Set the boost/3spd setup to "boost start" option, but not helped.
Tried Dc limit current set to 80A, and 30A but it is the same.
The full throttle voltage setup is 4,4V and real voltage when pulling is 4,5V, so should detect is at full throttle.
Do you have any idea what can i try, or this controller only capable this poor acceleration?
My other ebike with Kunteng controller max. 45A 18Fet and 1500W motor pulls 2000W and nearly accelerates like this, so this is why i am not happy, i expected more.
