Stromer ST1 broken after recup was used
mbarzan
Hi,
I'd like to ask you if it's worth to try to repair my broken Stromer ST1. :(
It is model from 2013, working perfectly for the last few years, but broken few days ago.
Long story short:
- recup was set during normal ride, about 60-70% battery left (not for a long time)
- I think LCD flashed a bit and suddenly powered off
- Stromer does not turn on at all
- The rear wheel (engine) is acting like the recup is turned on - no resistance at very low speed, big resistance at bigger speeds
The questions are:
- the rear tire was changed quite recently, can it be caused by some engine cables damage?
- does it make sense to try to repair the engine? Which part can be broken? I see that almost everything is in epoxy, so it might be impossible to be repaired in the end
Thanks and regards,
Marcin
