So my ebike battery stopped working all at once. The small push button gauge on the side doesn't light up when I push the button and It shows 0 volts when hooked up to a meter. This battery isn't that old, so I opened it up to take a look. The only part I can find inside that might be bad (as the switch tests ok) is what looks to be the BMS for the battery. I cant seem to find a replacement for it, and I thought I would ask here if anyone knows what I should be searching for to replace it.
The numbers on it are:
sp-m13-027-a01-m10sy-11205/1710270319
Any thoughts on where I should look for this?
