Hello, I am about to order DD hub motor with 175 mm dropouts. The dropout on my Trident Fat Trekker trike is 194mm. I can add spacers to make up the 19mm and keep the wheel centered, but that would mean that the derailleur limit would need to move inboard to make up the 9.5mm’s! Does anyone know if that much adjustment is likely? Not sure this would work, but I’d be okay with adjusting derailleur as far Inboard as possible, even if I lost a few of the lower gears. But I’m thinking that if I did that, that when I upshift to the highest gear I am move the derailleur to far outboard and snag the chain between sprocket and the frame. Can the bar end shifter be adjusted to help this? Any other ideas?
Im grateful for any suggestions,
Frank
Frank
