I would say the switch isn't necessary, but couldn't hurt, as long as it can handle the current internally without arcing.
The charger leads seem ok, but personally I would run it on a separate, lower amp rating fuse, instead of running thru the main fuse, as it might be too high a rating to protect the charger, esp if the motor one is a slow blow fuse that can handle short overloads.
