Hi all, as the title says, I have a bit of an issue with my new setup. It's my first time using the S09S sensorless controller. Motor is a Q128 36V and 201RPM winding on a (for now) 24V battery.
Top speed is a bit low as you would imagine, but the battery is capable of 7-800W in a pinch.
I also have an S-LCD5 display, on which I didn't change any setting at all.
The thing is, what seems to happen, if I hit a bit of a hill at low speed (5mph-ish) and full throttle the motor/controller just cuts out. The BMS doesn't cut - checked with live DC voltage readings.
Any pointers on where to start? The googling so far didn't surface many clues, but I have a sneaky suspicion it's the sensorless (because frankly it's the only new thing in this bike vs the half a dosen I built already)
Thanks for reading
Thanks for reading
