Julet 9 Pin Connector
LewTwo
Houston, Texas
I purchased a Julet 9 Pin Male-Female extension cable to use in rewiring my Golden Motor Smart Pie Front hub (control wires only). To accomplish my tak I needed to map the pin out and am uploading that information is case it could be useful to anyone else. Note that my "PIN NUMBERING" is arbitrary as I could not locate a standard numbering scheme. I believe that this connector is also the equivalent to the HiGo Z910. The ZIP file contains the original DWG file as well vector PDF and JPG images.
I believe this is the standard when used as a motor cable (under 500 watts):
  • Julet 9 Pin Male-female.zip
