Today I had rough running and higher than usual drag on my 3kw DD motor (with Statorade+Hubsinks). I push up to 20kw bursts through it and allow up to 135 degrees Celsius at the windings (thermal foldback starts at 110) and motor was close to 135 on this ride.
However it is not the first time it has seen this temperature.
I have attached pictures I took after opening the motor today. The rough running and drag was caused by those wooden sticks which had moved. Also the yellow insulation layers seems to have moved at some areas.
Anybody already had the same issues?
