Brodie
10 µW
- Joined
- Jul 25, 2021
- Messages
- 5
Hi everyone, new member here. I have been lurking and soaking up a lot of information before beginning my bike build. I am at the point now where I have ordered the battery, controller and nessecary attachments.
I was give an old 36v ebike with a front hub DD motor.
The battery was an old prismatic cell type that wouldn't charge higher than 33v.
So after a bit of reading on here I decided to move to a 48v system.
I have bought a 48v 15ah 30a continuous output battery, a KT 18Fet 45A sine wave and a KT LCD8H.
The plan is to run the controller at the half setting for a max output of 26a at 52v which is what I can figure a max charge 48v battery is.
But overkill on the controller but it won't have direct airflow where I was planning on mounting it so thought the bigger size might be better.
As for the motor. I am having trouble identifying it and need some help. From what I have read it should be ok to take the 1.3kw max that will get pushed through it.
Hopefully one of the experienced members here can tell me what I have via these photos.
Cheers, Brodie.
Cheers, Brodie.
