BMS Recoms for 36v 10s7P Pack
bobbill   100 W
Post by bobbill » Jul 28 2021 5:03am
What works and is dependable?
HK12K   100 kW
Re: BMSrecoms 36v 10s7P Pack
Post by HK12K » Jul 28 2021 6:47am
I frankly don't know much about them, but the ANT BMS seems to be fairly well regarded I believe.
bobbill   100 W
Re: BMS Recoms for 36v 10s7P Pack
Post by bobbill » Jul 28 2021 7:09am
Thank-you,HK,
I am a believer in "simple" and went through a very careful Vruzend assembly and had two failures (heat and out of balance stoppage) and do not wish to repeat.
The BMSs supplied worked well (I think) and if I do the larger pack, need similar assurance is all.
Seems I spend more time fixing than pleasuring, which is discouraging and time consuming.
Thanks again.
HK12K   100 kW
Post by HK12K » Jul 28 2021 9:58pm
Did you buy your batteries direct from China? If so they are most likely counterfeit, which would explain the out of balance issue.
markz   100 GW
Post by markz » Jul 28 2021 10:32pm
I have heard of others having problems with Vruzend as well, I bet the springs bounce.
bobbill   100 W
Post by bobbill » Jul 29 2021 3:50am
HK, bought 72 NCR PFs from parellelminer.com. Way low cost too, seemed to me.
Have to layout build plan,
Mark, V had no option to replace damaged components along with an attitude - forget them,
