MarkJohnston
- Joined
- Mar 25, 2021
- Messages
- 620
Hello,
I want to build a small and lightweight but high voltage battery. The point of this battery would be to over volt the motor temporarily to get a ton of speed i.e. 50 mph just for 5 or 10 minutes.
I have two batteries 54.6 10 amps that are linked in parallel. The turbo boost would be on an on off switch maybe directly linked to the motor. I am planning on re wiring the axle because of a pre exisiting damage/cut to the axle wiring. So maybe I could custom build battery wiring directly to the motor to deliver high voltage so the CONTROLLER DOESN'T GET FRIED.
