The Toecutter
- Joined
- Feb 8, 2015
- Messages
- 1,312
I currently have a Sempu 115mm spindle-width torque sensing bottom bracket. I'm going to soon upgrade the gearing on my custom velomobile built on a KMX framekit with a Schlumpf HS drive with a triple chainring set, which uses a special bottom bracket, meaning I'm going to need to use a different type of torque sensor. Torque-sensing PAS is important to this build and I require it for a series of reasons, some of them legal reasons. Whatever torque sensor I use must be compatible with my Cycle analyst v3 computer and must be something I can fit to my current build.
Anyhow, I've come across the following:
https://idbike.com/sensors
I have a Leafbike 1500W motor and the axle width is limited. So limited I cannot fit a Grin torque arm on the chaindrive side of the motor for regen. So I'm not sure this will work. But it's a distant possibility.
What types of non bottom-bracket torque sensors exist that are readily available? Ebikes.ca had a list (https://ebikes.ca/learn/pedal-assist.html), but most of their links are defunct. I've come across lots of sites with links, most of those links out of date linking to products that no longer exist.
