DIY Mini ebike battery configuration system
papo2110
Let me know what you guys think I should have done better it works great but I would appreciate some input
https://youtu.be/BaZfpErxDTY
C-rate is always proportional to Ah
So C-rate stays the same as you add more packs, paralleling or in serial.
The wiring harness is fine long as you know what you're doing.
Make sure packs you parallel are the same S-count **and** very close to same voltage before connecting.
IMO the rig is dangerous if others are involved.
Yup. You don't want anyone unfamiliar to plug a bunch of packs into the series connectors, then accidentally plug one into one of the parallel ones. :shock:
Yes thank you actually I am going to 3D print a blank cover plate one for the paralle plugs one for the series plugs
