Upgrade Flipsky 75100?
rg12
It's rated for 120A peak phase and the software only outputs 110A no matter what I type in the current section.
I would like to upgrade the mosfets and use a higher current and would like to know if there is an option to bypass that software limit.
rg12 said:
Oli.Hall said:
You would have to recompile the firmware below with increased current limits
How to update firmware on the Flipsky 75100 FOC ESC
https://forum.esk8.news/t/how-to-update-firmware-on-the-flipsky-75100-foc-esc/61819
Ahh thanks alot!
Any recommendation for the best mosfets out there that fit the 75100?
Managed to kill my 75100 in 3 min while testing over temp protection - fused gates of 2x FET's,
From what I checked, there are no real upgrades worthwhile in the TO220 package.
What I was thinking about is to double up the amount of FET's.
Basically making a 12FET design. This would "theoretically" increase limit to 200A.
I do think its not that simple, probably traces will start melting?
Do we also need to add any extra gate resistors etc?
This is the stock FET - mdp10n027
Ahh thanks alot!
Meanwhile I'm running it pretty hard on my scoot with a 72V battery.
Running 180A phase current bursts :lol:
It's all about the cooling.
