No sensor and temperature poles, does it work?
pmg   10 µW
10 µW
Post by pmg » Jan 16 2022 3:13am
Hi, I have a 36V Panasonic battery with these 5 pole connectors:
I was wondering if the standard charger and bike would work without the ‘S’ (sensor?) and temperature poles connected?
amberwolf   100 GW
Re: No sensor and temperature poles, does it work?
Post by amberwolf » Jan 16 2022 3:04pm
pmg wrote:
Jan 16 2022 3:13am
Depends on how the BMS is made to respond. What happens when you try measuring the battery voltage at the main + and - pins? If it doesn't require those to be communicating / etc with the charger or bike, you should read a voltage on them. If it does require that, then you'll probably get no voltage on them, or a lower-than-expected voltage that will "go away" (drop fairly quickly to zero) with any load at all on them.
If you found this advice helpful, supporting contributions are accepted here.
Beginning of a New Life
Give a listen to my music!
(More here, including experimental).
pmg   10 µW
10 µW
Post by pmg » Jan 17 2022 4:26am
Thanks for your answer.
I mean if I used a new battery pack (new cells and new generic BMS).
Because it would be a generic BMS I would only have + and -, so I'm wondering if it would work.
Unfortunately I don't have neither the charger or the bike to test it...
E-HP   1.21 GW
1.21 GW
Post by E-HP » Jan 17 2022 11:28am
pmg wrote:
Jan 17 2022 4:26am
It's unclear to me if you are trying to adapt a proprietary battery to a non-factory ebike, or if you are trying to adapt a generic battery to a factory ebike. Can you restate your objective?
pmg   10 µW
10 µW
Post by pmg » Jan 17 2022 12:58pm
Sorry for not having provided enough information.
I'm actually interested in knowing the outcomes for a generic battery adapted to both a factory and non-factory ebike.
E-HP   1.21 GW
1.21 GW
Post by E-HP » Jan 17 2022 2:54pm
pmg wrote:
Jan 17 2022 12:58pm
Generic battery had two discharge leads. DIY ebike controller has 2 input leads. No issues.
Factory ebike battery may have more that 2 leads to communicate with a factory controller. The extra leads may be required for the factory controller to work, or may be required to turn the battery on/off. No issues, if the factory battery is designed to work with the factory controller.
Factory battery to DIY ebike controller might work, if the additional wires of the factory battery are not required to turn the battery on/off. Otherwise you have issues.
Generic battery to factory controller might work, if the factory controller doesn't require signals from the factory battery to function. Otherwise you have issues.
I think that covers the various permutations.
pmg   10 µW
10 µW
Post by pmg » Jan 18 2022 10:20am
Thanks, that covers it :)
