What is the difference between the controller S-KU63 and S06P?
I think they are the same
I asked this to BMSBattery but got no answer.
https://bmsbattery.com/home/1021-s-ku63 ... v-15a.html
https://bmsbattery.com/home/1012-s06p-2 ... oller.html
S-KU63 vs S06P controller at bmsbattery.com
Re: S-KU63 vs S06P controller at bmsbattery.com
One needs a display and the other doesn'tavandalen wrote: ↑Jan 22 2022 8:01amWhat is the difference between the controller S-KU63 and S06P?
One had a 3 speed switch (the one without the display), and the other doesn't
One supports dual mode (sensored or sensorless) and the other doesn't
One uses the display to turn on or off (or requires a jumper) and the other uses an external switch to power on
my econo-e-bike https://endless-sphere.com/forums/viewt ... =6&t=97945
- avandalen 100 W
- Contact:
Thank you, I will take the S-KU63.E-HP wrote: ↑Jan 22 2022 10:15amOne needs a display and the other doesn'tavandalen wrote: ↑Jan 22 2022 8:01amWhat is the difference between the controller S-KU63 and S06P?
Now, I use the older KU63 for 8 years on my solarbike (Maxun One) which has motor voltage control but I want to have motor current control. I suppose, S-KU63 is the successor of the KU63.
If you have some current in reserve you could look at the s09p-bl which is 22A
https://bmsbattery.com/home/849-18288-s ... s-app.html
I use one of these sensorless with no display and it works great (need to disconnect the auto cruise control wire tho!!)
- avandalen 100 W
- Contact:
I have updated my article with the answers I got here..
https://www.avdweb.nl/solar-bike/electr ... controller
