Hi guys,
After a few years absence from e-bike building I'm back on ES once again, trying to remember all sorts of technical Ebike stuff I knew a couple of years ago
I have a 2014 S-pedelec (cheap and obscure brand that doesn't exist anymore) that I bought used in 2018. Since then, I've used it as a daily commuter. Apart from a new battery, it has run without any issues.
Current setup:
Bafang (8-Fun) 500W rear hub motor (with at least 15.000km in all weather conditions on it, possibly a lot more. Still runs great!)
Lishui LSW772-96F 48V 20A controller. Date of mfg. 2014.
Bafang 850C display (uses non-Bafang firmware made by the bike company that has some limitations, like speed limit of 45km/h that can't be changed as that is a legal requirement for S-pedelecs here)
48V20Ah battery pack
Lately I've had some issues that I think are due to a bad controller, but I would like your opinion:
Last week when I took it off the charger I noticed that according to the display the battery was at 56V.
After panicking that the charger/BMS somehow overcharged/destroyed the pack I took out my multimeter and measured the battery to be at a perfectly fine 52V. Since then, the voltage indicator on the display has consistently read too high, but everything works fine.
Yesterday the PAS started cutting out. While pedaling, the power would cut randomly, to come back after a random time and cut out again. There are no errors displayed. The display has no 'PAS active' indicator, so I can't see if it is registering pedaling.
When using the throttle everything worked fine, but throttle is limited to 25 km/h
Suspecting a dirty/faulty PAS, when I came home I cleaned the PAS and checked the wiring.
The PAS LED blinks every time a magnet passes, magnets and gap are OK, so the PAS seems fine, but there is no response from the motor.
Link to image of the controller:
https://ibb.co/F5LT9R3
The controller is hidden inside the frame (and is a major PITA to remove/install). It has suffered no water/moisture damage and all connectors inside the frame look like they were made yesterday. But it still is an 8 year old controller with a lot of km's on it. Combining that with the issues above makes me think it is time to replace the controller. But with what?
I've read this topic that updated just a few days ago https://endless-sphere.com/forums/viewtopic.php?f=2&t=116101 with great interest. If possible, I would like to replace the controller with a KT 22A controller as well. It looks like they are made in different configurations, with a 'Bafang' style as well, that seems to match the waterproof connectors on my bike. (It has the 4-to-1 connector that my bike has as well)
Would I be able to still use my current Bafang 850C with such a KT controller? Or do I need to get the KT-LCD4 as well?
Last question: as I need this bike for my daily commute, are there any local webshops that ship to Belgium within a few days?
Searching turns up a few UK shops, but they don't ship to the mainland.
I used to order my ebike stuff from BMS battery or Aliexpress but this time I cant afford to wait for a month for new parts
Current setup:
