Torque sensor issue
Omad24
Hi new member here and have a technical issue.
I have this controller
Which has 5 wires for the torque sensor going in to the controller. I damaged the cabe on the torque sensor and on trying to repair the cable found in had 6 wires. I matched up the wires. I can get the torque sensor to work but on switching the system on the torque sensor will not work unless I remove a metal sleeve inside the bottom bracket and reinstall then the sensor works. I'm confused to why it does this.
I have attached pics of the torque sensor and the inside of the controller.
Can anyone help?
