Rear hub making weird noise
Hi. I am almost done making my first stealth bomber but I ran into a little issue. Just to let you all know I have never road this ebike yet. But the problem is that there is a strange rubbing noise that wasn't there before and it just started. I was testing the throttle on my ebike and then I noticed that the wheel came to a sudden stop and the single speed freewheel was coming loose and made the wheel stop. So I retitened it and now it's making this noise. Here is a link to the video. https://youtu.be/Y667FTNYYz8
I also tested it while it wasn't connected to the
controller or battery and it still made the noise
I hope someone knows what it is thanks.
Edit: took the freewheel off and the noise is still there must be coming from the inside, any ideas?
it looks like the freewheel is rubbing on the dropout which is why it's loosening too. you need a washer/spacer.
I took a look and it doesn't look like it rubbing on the dropout to me. Someone online told me it could possible be the bearing since it stopped so quick, but I'm not sure yet since I haven't opened it
I took the freewheel off and the noise is still there must be coming from the inside, any ideas?
Loose magnet in the rotor? Some other foreign object in there?
If the axle bearings are shot and let the axle move relative to the hub shell, the stator and rotor could be making contact. If you can rock the rim side to side when the axle nuts are tight, this is a clue.
Open up your motor! And post photos, please.
I was thinking about that, but the bike has never run, so it didn't get dislodged by heat, so it would be like that from the factory.
will do I'm going to be opening it tomorrow. The motor spins smooth and has no rocking or anything loose feeling to it, it just started making that light rubbing noise after the wheel locked up.
Yeah the motor has never been used yet, I have just been settings things up in the controller settings and the bike has been on a stand the whole time for testing purposes.
Doesn't mean it's not a magnet or something else bouncing around in there, but less likely than if you had run the motor hard. I have no idea what kind of quality control they have making those things, or if they test run the motors before sending them out the door.
Yeah I'm starting to think its a magnet slightly rubbing against the casing. I know right, I really hope they are testing these things before they box them up.
Here are the photos of it being apart nothing looks like it was rubbing to me. Is it normal for the magnets to be touching on one side and not the other?
I posted some photos if you wanna see what you think of it
That would be a bad thing when the motor is assembled. When it's open, you might just be seeing the rotor tilting because it's unsupported on one end.
If magnets are rubbing, you probably won't be able to tell without lifting out the stator. But that's when the magnets get a chance to bite your hands. So be careful.
I would pop the stator out just to get a full picture of what's going on. You may be able to tell right away if it's rubbing against the magnets, but any rub marks, etc. Plus you can see what's going on the other side in case something else is loose and flopping around. Be careful.
Thanks for that info. I actually was just looking at the bearing once again and I'm starting to think its the bearing. When I held the side case with the bearing in it and spun it on my finger I can feel something hitting over and over, it's also not spinning smooth either. I ordered a new one and its gonna be here tomorrow, ill be giving a update on if it makes a difference.
I actually was just looking at the bearing once again and I'm starting to think its the bearing. When I held the side case with the bearing in it and spun it on my finger I can feel something hitting over and over, it's also not spinning smooth either. I ordered a new one and its gonna be here tomorrow, ill be giving a update on if it makes a difference. If that doesn't help I guess I'm gonna have to pop out the stator.
