Best Direct Drive Hub Motor that weighs 10Kg or less and has a 40mm or larger stator?
Bullfrog
Two part question....
A. Are there any good quality Direct Drive Hub Motors that weigh 10Kg/22 lbs or less and have a stator that is 40mm or taller besides the ones listed below:
MXUS 3K Turbo motor (9.8 Kg)
Crystalyte H55 series (10 Kg)
Crystalyte Crown series (8 Kg)
B. For all of the motors listed in part A. above, which one is the Best if "Best" is determined solely by the quality of the motor AND why is it the best in your opinion?
I realize the 10Kg limit rules out the QS205/273 and the Cromotor and the 40mm stator minimum rules out the Leaf motor...all of which I consider good quality motors just that they are outside the scope of this discussion. Grin Tech no longer offers the DD45 motor and that is the reason it is not listed.
Thank You for your assistance.
