I just bought a 52v Kepler bike. Overall the bike is very good especially given the price. I noticed that my battery would only go up to 56.3 volts but when you turn on the bike the display says 100%. I assume this is to extend the life of the battery and it's what I typically charge my batteries to. That said, if I'd like the option of occasionally charging over 85%. The charger puts out 58.8v. Do you guys think this is built into the charger or could something like this be built into the BMS? If it's built into the BMS, can I charge it through the power output xt60 connector rather than the charging port to charge higher than 85%?
