Cycle analyst 10v to 5v
longwood
10 µW
My bike has a built in PAS sensor, it's cleanly tied into the bottom bracket. OEM system is 5V.
I would like to run this with the CA, how ever I know the CA is 10V.
What is the most simple way to do this? How much current is really drawn from the PAS circuit?
Can I simply use 5V from throttle supply to power the PAS and avoid any extra components?
https://ebikes.ca/amfile/file/download/file/35/
You must buy and install this small item.
https://ebikes.ca/miniature-5v-pas-regulator.html
Thank you!
