Connecting LED S810-H Display
Hello All. I am struggling to connect my display to the controller. The display has the following wires: red-positive, black-negative, blue-controller electric door lock, green-gear signal, yellow-headlamp positive and brown headlamp negative. The controller is a Brainpower SL-QX132KZ. I have attached photos for extra info. Any help would be greatly appreciated. Regards, Andy
If it didn't come with the controller, it is unlikely to work with it. Displays and controllers are not generally intercompatible, and should be bought as a "kit" or set, together, to be fairly sure they will work together.
If the controller doesn't normally come with the same type of display, it is virtually certain not to work with it. (if you don't see anyone selling that exact controller with that display, there's about zero chance of compatibility).
