Hyena
10 GW
Hey guys,
I was wondering what peoples experiences are with the programmable infineon controllers in terms of how much rated and phase current you can get away with. I guess the theoretical limits of the components are a good place to start!
Obviously the boards need to have the traces physically built up enough to handle high current, but what will the fets allow ?
Anyone got any data or anecdotal evidence ?
I'm particuarly interested in what can be squeezed from the little 9 and 12 fet models - with either 4110s, 4310s or even the commonly used 75a NF75s ? I have to admit the technical intracicies of high side and low side fets escapes me, but for example with a 12 fet controller running 100 amp rated fets, could I assume it will take up to 200 amps ? If the rated current is normally 30 amps and the phase current is 70 amps, if you double the rated current to 60 amps is it going to handle a phase current of 140a ?
The reason I'm curious is I've been experimenting with different controller programming lately and I'm wondering what sort of phase current is safe to use without risking popping the fets. Ideally I want the most punch from the smallest controllers but with reliablility. 40 amps from a 9 fet and 60 amps from a 12 fet is my goal, which I think is reasonable...
