lemmiwinks
Just wondering what peoples thoughts were about the potential for a Crystalyte x5 hub motor in an electric motorcycle. I'm talking about a conversion of an ICE powered motorcycle, not a super beefed up bicycle of some kind.
Joshua Goldberg claims that you can order a Crystalye with any diameter axle you want, so say an axle of between 19-25mm (which is a good range for average sizes of motorcycle rear wheels), would that be possible? Then there's the spoke flanges, they'd have to be custom drilled because motorcycle spokes are much, much larger than bicycle spokes. There might not be enough material in the flange.
Also, would it have enough grunt? For my own (currently stalled due to lack of motivation) conversion, I'm aiming for 48V and about 50Ah because that's what I can reasonably carry on the motorcycle with affordable batteries that are capable of high current discharge with little voltage sag. Yep, SLA. So maybe 48V @ 100A / 150A peak. Is there such a controller available from Crystalyte?
Using the simulator I got a peak of about 1200W with a 5304 and a 35A controller, torque was pretty good too. Using a 20" wheel (motorcycle wheels are measured differently than bicycle wheels, but 20" is closer than 16") speed topped out at about 50kph but from the torque curve it looked like 30 is more realistic. If you couldn't pick the speed up it's not much good. A 5302 looks promising, but I have no experience with any Crystalyte motors so I don't really know what's a good one to pick.
Hub motors aren't my first choice as the EVT has one, and their limitations become apparent fairly quickly, but if you could just pour the amps in with no ill effects (like overheating on the brushed EVT motor) then maybe a brushless hub motor like the Crystalyte could be good? It would certainly make for a very simple conversion. Get the motor with a disc brake adaptor, lace up a wheel, mount batteries and controller, bolt wheel in (might have to modify swinging arm as motorcycle axles slide out of the wheel normally) and off you go.
Thoughts?
Thoughts?
