Adaptto Mini-E/Max-E Owner's Thread
wingsuit   100 W
Re: Adaptto Mini-E/Max-E Owner's Thread
Post by wingsuit » May 26 2015 1:33pm
moonshine wrote:
striker54 wrote:
moonshine wrote:I've been looking around and have not been able to find a specific setting enabling balancing on the BMS. I have my bms connected and I set it to be enabled. I also see the cell voltages but the BMS board isn't flashing or seem to be balancing.
Anyone have any input on what I'm missing? Is there a specific setting? The BMS status keeps saying "no" next to "bat balancing"
In the BMS menu you have to configure the type of cells you have (lipo, life, lion) and you also have a custom mode where you can set the max cell voltage, the balance voltage, minimum voltage, etc). What have you selected???
I chose "custom" I believe i put in max cell voltage as 4.10, min as 3.10, critical as 2.5, balancing as 4.10. I'm running samsung 25R cells. Should i be putting in max as 4.2, min 3.1, and critical 2.5? I wanted to increase longevity of cells so i thought charging them to 4.10 down to 3.10 was a good range. That means i set my charge voltage to 82V, high voltage cutoff to 84V with 1V softlimit. I'm not sure if that's the correct way. What have people been doing for 18650 cells?
you'll want to put balancing below max cell voltage. if max is 4.1 and balance is 4.1 it probably wont kick in.
mine is max cell voltage 4.12 balance voltage at 4.06
this way at you approach the top the balancing kicks in
moonshine   1 kW
Post by moonshine » May 26 2015 1:51pm
striker54 wrote:
OK, there is another menu (that i don't remember the name)in the BMS menu where you need to set the number of cells in each plug board
Yep, i remember that one. I just configured everything to channel A (using 5 boards but burned the 2nd board...haha). I set each board for 4 cells (20s8p). i can see them just fine, i just want to make sure they actually balance because i seem to be charging w/o balancing. One time the charger stop at 79V or so (82V cutoff) and i couldn't figure out why until i checked the bms and saw one cell was 4.26 and another was 3.65. I flipped my shit for a few seconds. But after a minute or two...and checking the bms connections the cells all went back down to normal ranges around 4V. That's when i realized that none of the cells were actually being balanced but rather just bulk charged.
Current Build: Vector, MXUS 4T in 19" moto, Max-E, 20s8p Samsung 25R http://endless-sphere.com/forums/viewto ... =6&t=67752
Torque Raptor, Cromo V3 in 19" prowheel, Kelly KBL96251, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =9&t=56342
Giant DH Comp, X5404/Cromo V2 in 26" rim, Kelly KBL96251/Lyen 18fet, 24s4p (SOLD) http://endless-sphere.com/forums/viewto ... =6&t=40031
moonshine   1 kW
Post by moonshine » May 26 2015 1:55pm
Ok, well i'll set my max cell voltage to 4.20, and balance to 4.10. I guess it doesnt matter what the max cell voltage is since i will set the max battery charge voltage at 82V. Right?
skWarDog   100 W
Post by skWarDog » May 26 2015 2:44pm
skWarDog wrote:
Allex wrote:Dunno about rc7c, b is what I used and what doc uses now.
That's actually what I wrote to the SD Drive, and now the drive letter don't show up in windows explorer (I understand this is normal), so saves me a trip to Staples. I'll give 'b' a try...... It did write successfully, thanks for posting the translation @ 40 pages back, Allex! I'm sure I'm not the only one in this thread who appreciates all the really accurate knowledge you contributed to this thread and forum!
Damn-it!!! So today I tried to flash rc7b. D/L good, using the utility successfully wrote it to a PNY SDHC 4GB memory card. Put the card in the display, powered system>press "left" update>press "left" update all....
SD OK 1%
CRC is good 10%
LCD Deleted 15%
LCD Updated 20%
Write to Controller 1-100%
Update Successfull! Remove SD Card. Restart Controller. 100%
Upon restart, all I get is a blank screen????
HELP ME PO-LEASE!!!!!
Edit: Prefomed Hardware Test from SDHC- All buttons work and current to throttle(0799), brake(0763) and the other thing(0163).
There was also another "Display Update" and I saved those settings as prompted without changing.
Reflashed rc7b again.... same result!?? Display is backlit but blank, throttle does not respond either
"Whiskey for Me, Electricity for my Horse"
If you can't Dazzle them with Brilliance, Baffle 'em with BS!
Tits SuMo Juice Bagger http://endless-sphere.com/forums/viewto ... =6&t=65448
[+] sk
silent killa
Offroader   100 MW
Post by Offroader » May 26 2015 4:20pm
SD OK 1%
CRC is good 10%
LCD Deleted 15%
LCD Updated 20%
This is exactly why I'm a bit hesitant to reflash my controller. Especially with the nice weather just starting.
skWarDog   100 W
Post by skWarDog » May 26 2015 5:16pm
Offroader wrote:
skWarDog wrote: Damn-it!!! So today I tried to flash rc7b. D/L good, using the utility successfully wrote it to a PNY SDHC 4GB memory card. Put the card in the display, powered system>press "left" update>press "left" update all....
OK, I'm fixed! I ended up flashing rc9e (upgrade for me from 9b), but was not able to flash rc7b...
My observations:
1) I think if you have a newer controller, Adaptto may have reconfigured something (processor?) so you can't flash back that far. Just a wild guess?!
2) I also tried the Doc B LS Tune Trick.... FAIL!
Theory- I have a batt with an internal BMS witch cuts it at 50amps, witch my "Boost" profile is set at 49.8amps. I tried setting the LS current at 52amps, that caused shutdown. I turned LS current down to 49.8amps, no problems, but no gain either. So, I just turned it off.
So basically, I'm back to where I was yesterday. Minus $20 for a couple SDHC memory cards...... That's all for now
[+] sk
silent killa
ohzee   1 MW
Post by ohzee » May 26 2015 5:33pm
Where are people getting rc9f ?
Doctorbass   100 GW
Post by Doctorbass » May 26 2015 6:10pm
ohzee wrote:Where are people getting rc9f ?
From adaptto directly. When i received mine back from repair it had rc9f
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
Brake   100 W
Post by Brake » May 26 2015 7:28pm
Hey Doc,
Do you have a part number for those 1000uF 18 milliohm ESR caps you installed?
Ohbse   10 kW
Post by Ohbse » May 26 2015 7:28pm
striker54 wrote:
Offroader wrote:What is this LS tweak, I tried looking back in the thread but couldn't find much information about it.
Second picture: http://endless-sphere.com/forums/viewto ... 5#p1050630
You need to set a current equal or superior to the batt amps set in the profile boost and adjust the LS start speed where it kicks in.
This screen is actually a bit different on the later firmware versions, you don't specify a speed at which LS starts, but where it ends. I extended the LS end to 75km/h and to 80a and it definitely had the desired effect. My earlier point regarding phase amps stands however, at low speed the phase amps are still limited to your power profile setting (in my case as high as it will go in boost with the locked firmware) however battery amps will increase. That means at low speed where you're not reaching battery amp limit it will make no difference.
6.7kw maximum registered on this mornings journey in, feels good.
Offroader   100 MW
Post by Offroader » May 26 2015 10:04pm
I played around a little with the LS setting, I set it to 83amps, my battery amps are 76. I set the LS start at 00 MPH.
What I noticed is that the front of the bike lifts up higher at first, but a second later the bike bogs down or loses power. I guess this is the phase amp limit hitting. Because of this it wasn't really worth messing around with it anymore.
Doctorbass   100 GW
Post by Doctorbass » May 26 2015 11:39pm
Brake wrote:Hey Doc,
These was from another Lyen controller.. Sorry i dont have any part number. However use the digikey parametric search tool, you will find some even better!
DOc
Brake   100 W
Post by Brake » May 27 2015 1:05am
skWarDog,
There is different firmware for the screen and the controller. Your display firmware may not be compatible with the older controller firmware that you installed. I haven't tried updating the display separately, so I can't help there. Try going back to the rc9 if nothing else.
Brake   100 W
Post by Brake » May 27 2015 1:07am
Thanks Doc, I ordered some and we will see. Guess I have to get an ESR meter now. [SMILING FACE WITH OPEN MOUTH]
burner77   100 W
Post by burner77 » May 27 2015 3:35am
Does anybody know which thermistor is in the Crystalyte 5403 by stock and if it's supported by Adaptto?
Usually Crystalyte is using NTC 10k but it seems to be another one… Thanks
Boestin   100 W
Post by Boestin » May 27 2015 3:53am
burner77 wrote:Does anybody know which thermistor is in the Crystalyte 5403 by stock and if it's supported by Adaptto?
Same question here for the crystalyte hs4080, tried every possible option, I even switched the sensorcable.
Have you tried that burner77?
ridethelightning   1 MW
Post by ridethelightning » May 27 2015 7:14am
best just cut it out and solder in the adaptto one that comes with the controller. completely painless op. just stick it in there with rtv gasket silicone...
Allex   10 GW
10 GW
Post by Allex » May 27 2015 7:54am
SD OK 1%
CRC is good 10%
LCD Deleted 15%
LCD Updated 20%
I had to hit back button to wake it up.
Post by ridethelightning » May 27 2015 9:01am
yep, one of my displays does that from time to time too.the rc7c mine-e one.seems to be when iv let it sit for a while without use..have to hit any key and it wakes up again.
it is often asleep when i turn it on with the red wire switch too. its funny. it boots and displays the firmware version, then goes to sleep again, and i have to wake it up.
ohzee   1 MW
Post by ohzee » May 27 2015 11:49am
Could anyone recommend their settings to try who has a mxus 3000 v1 with a max e locked ?
Running 20s9p 25r's so I feel I should be able to push it well.
I feel I should be able to get more from the motor , but so far have been hesitant to push the settings to far.
I have seen where some people listed their cromotor settings just not any for the mxus tho I very well may have missed some. Thanks in advance.
skWarDog   100 W
Post by skWarDog » May 27 2015 12:17pm
Allex wrote:I had to hit back button to wake it up.
Oh, believe me, I hit every button at least 10 times to try and wake it up! And like I said, I tried the hardware tests (pass) and saving the LCD settings a function on the SD memory card.....
It did cross my mind to try what Brake suggested:
Brake wrote:skWarDog,
But I was happy to have SuMo lit-up again and running firmware rc9e, cus it was 80 degrees and sunshiney here yesterday and I didn't want to be in that damp cold basement room with a....... Well, daylight was burnin, my batt pack was fully charged.... It was time to tox a fatty, hop on SuMo, dance down the D&R Canal towpath right into dowtown Trenton and burn down some of those hucks I been scoping out:
Planet of Terrium 2.jpg (119.46 KiB) Viewed 2282 times
Planet of Terrium.jpg (98.07 KiB) Viewed 2282 times
WW2 Memorial Hucks.jpg (174.07 KiB) Viewed 2282 times
WW2 Memorial Huck.jpg (148.98 KiB) Viewed 2282 times
You see, I'm still invisable to the Po-Po because I'm the only person I know in my area who has a weapon like this. As a matter of fact, yesterday I was hucking-up General George's (his pic is on the dolla bill) old barracks, which is now a NJ State Pork Pen and the Trooper's going in and out were giving me the "that's cool" wave! So, right now, the only one who can ruin e-riding in my area is me, that's why I try to keep a low-pro and if anyone asks me about the extra's on my bike, I tell them things like, cable TV, GPS trail mapping equipment for Google Earth, Russian Republic satellite receiver, pedal stroke amplifier, etc..... amazing how gullible people are!!!
I'm sure once all the blockheads get ahold of this tech, it's all over, now is my time to fly>>>>>>>>>>>>
[+] sk
silent killa
burner77   100 W
Post by burner77 » May 27 2015 2:10pm
There are some Crystalytes with 1 wire and some with 2 wire thermistor. The 4065 had two and it worked for me, using 10k NTC setting. But I will plant the Adaptto one to the stator
Post by ridethelightning » May 27 2015 3:56pm
one end to the black gnd wire, other end is to the adaptto thermistor pin in halls plug :wink:
Boestin   100 W
Post by Boestin » May 27 2015 4:05pm
ridethelightning wrote:one end to the black gnd wire, other end is to the adaptto thermistor pin in halls plug :wink:
Nope, not working here. I think the thermistor is broken inside the hub.
Hey, maybe that's why Adaptto gives us a thermistor..
wingsuit   100 W
Post by wingsuit » May 27 2015 8:06pm
all i want is more torque. I spend all kind of time thinking about how to tweak my mini-e to get better off the line speed.
my top speed still only hits 55kph on flats and 70kph on downhills but how fast it gets there seems a shame. never really seems to pickup until after 15kph.
need to spend more time tweaking settings.
has anyone with a mini managed to get it to feel snappy off the line?
