Known to Work Brushless Motor/Controller Wiring Diagrams
docnjoj   100 GW
Re: Known to Work Brushless Motor/Controller Wiring Diagrams
Post by docnjoj » Sep 28 2009 12:04pm
It actually works! I am stunned! Bafang to W/E sensorless controller!
B-B
G-Y
Y-G
Throttle as is yours but W/E throttle wire is Red=+5volts
Black= Neg ground]
White=signal
Purple=36 volt for LEDs
Starts right up and about the same growl as the sensored Infineon gives. Works fine!
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
El_Steak   10 kW
Post by El_Steak » Nov 15 2009 8:34pm
Methods 100V 100A modified Crystalyte controller to ebikes.ca rear 9c.
Power (Phase)
Blue to Blue
Yellow to Yellow
Green to Green
Hall
Red to red
Black to black
Blue to Green
Brown ? to Yellow
Yellow to Blue
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: http://endless-sphere.com/forums/viewto ... =6&t=17166
s_t   10 mW
Post by s_t » Dec 27 2009 10:02pm
Motor - Yucheng SWXJ, geared, no freewheel
Controller - ecrazyman 36V 350W
Correct combination:
Phase: Motor :arrow: Controller
B :arrow: B
G :arrow: Y
Y :arrow: G
Hall: Motor :arrow: Controller
B :arrow: B
G :arrow: Y
Y :arrow: G
Pos :arrow: Pos
Neg :arrow: Neg
Will run with the wrong combination of all colours matching, but draw high amps, get hot and probably 'let the smoke out' eventually...
Mark_A_W   100 kW
Post by Mark_A_W » Jan 11 2010 5:11am
MAC Shanghai and E-crazyman Infineon (18FET in this case, but I don't think that matters):
Phase
Blue to Blue
Yellow to Green
Green to Yellow
Hall
Red to red
Black to black
Blue to Blue
Yellow to Green
Green to Yellow
Edit: I had it wrong, it's corrected now. Full-throttle figured it out.
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Karisma   100 µW
100 µW
Post by Karisma » Jan 31 2010 6:30pm
GL1 motor to ecrazyman controller (found this combination on the 13th guess)
(Controller - Motor)
Hall sensors
Blue - Yellow
Green - Blue
Yellow - Green
Motor phases
Blue - Green
Green - Yellow
Yellow - Blue
Lyen   10 kW
Post by Lyen » Mar 13 2010 1:53am
This thing will figure out the phase degree, phase sequence, hall sequence, etc. for you. PM me if you want one. :)
http://www.youtube.com/watch?v=H5P1WBHso6k
Items For Sale
Please sign up here and donate your marrow to save life.
grindz145   100 MW
Post by grindz145 » Apr 20 2010 8:05pm
karma wrote:got it for the goldenmotor
Crystalyte v2 to goldenmotor
phase
B-Y
G-B
Y-G
hall
B-B
G-G
Y-Y
:mrgreen:
I used this setup for my Golden Motor with an 18 fet controller. It worked....in reverse:D
Does anyone have a recommendation how I can modify this to reverse the order?
I've tried a bunch of things that would make sense given my understanding but it hasn't quite worked properly going forward yet.
Thanks!
Speedfreke   100 W
Post by Speedfreke » Apr 29 2010 9:35pm
I have an old 408 xlyte motor and want to attatch this to an analogue 36-72v 35amp xlyte controller with different connectors for the motor and hall effects. Since they're both xlyte, will the wire colors match ?
rkosiorek   1 MW
Post by rkosiorek » Apr 29 2010 9:46pm
Crystalyte motors using different connectors - yes they will match as long as they all have the same colors to begin with. connect yellow to yellow, green to green and blue to blue.
some of the harnesses using the molded trailer connectors had yellow, white, green wires.those wires will not match correctly. i'll try to find my notes to see if i can find which is which in that case.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
Speedfreke   100 W
Post by Speedfreke » Apr 29 2010 9:59pm
thanx rick - yes I have the old trailer hitch connector on the 408. It is a triple connector (2 female, 1 male).
jtbball   1 µW
Post by jtbball » May 07 2010 9:43pm
Noob to brushless. Need help.
Using a Kelly KBS48121 and a 750W Ebikekit.com motor.
Can't seem to find a working combo. Anyone have this one?
Thanks
amberwolf   100 GW
Post by amberwolf » May 08 2010 12:56am
That has a "High pedal protection: Disable operation if power up with non-zero throttle." Sometimes that might cause no combo to work if you have the throttle type wrong. Probably is made or programmed for pot throttle, if using a hall it won't be zero volts output like it would with a pot, even at zero throttle.
GrayKard   10 kW
Post by GrayKard » Jun 07 2010 9:36pm
Cute 85 hub motor with Lyen 6 fet controller. I will find out if it has a reverse jumper and the state.
Phase wires:
Yellow :arrow: Blue
Blue :arrow: Green
Green :arrow: Yellow
Hall sensors:
Blue :arrow: Blue
Yellow :arrow: Green
Gary
toaroa   100 mW
Post by toaroa » Jul 30 2010 7:28am
Bafang jewel (QSWXK) > Persino PS-CN36V250WNHS Sensorless Controller (14A)
Blue > Blue
Yellow > Green
Green > Yellow
3 wire throttle > Controller
Red > Red
Green > Gray
Black > Black
(Everything else disconnected)
grindz145   100 MW
Post by grindz145 » Aug 14 2010 12:01am
johnrobholmes wrote:Infineon/ ecrazy man controller to 9 continent motor from Ebikekit.com. Same as the majority of Bafang motors
Power
Blue to blue
Yellow to green
Green to yellow
Phase
Red to red
Black to black
Blue to blue
Yellow to green
Green to yellow
no load current on 18s lipo was right about 1.5 amps. I think I got up to speed, my stand was shaking like crazy from the unbalanced tire :lol:
I used this same configuration for a 9C (ebikekit) motor and a Lyen build, Infineon 12 FET controller. Thanks again. Probably has to be my favorite thread on the forum:)
adigturbo   1 µW
Post by adigturbo » Sep 21 2010 1:00am
Hi,
First post on a very useful group of Forums, so I should contribute!
Kelly Control KBS48051E :arrow: Cyclone 900w Motor.
Hall:
Kelly :arrow: Cyclone
Black (ground) :arrow: Orange.
#5 (5v) should be orange, but mine Yellow :arrow: Yellow
#16 Blue :arrow: Black
#17 Green :arrow: White
#18 Yellow :arrow: Red
Phase:
Same Combo as above.
1000watt   10 W
Post by 1000watt » Sep 25 2010 12:41pm
Trying to figure out the wiring: GoldenMotor 1000w Brushless Motor to Infineon EB809XC-A-12 Controller.
I connected all the halls and phase, color to color and I got nothing.
I read that maybe the wires should be like this?
Halls
Infineon---GM
Black >>> Black
Yellow >>>Blue
Blue >>> Yellow
Green >>>Green
Red >>> Red
Phase
Infineon-----GM
Yellow >>> Blue
Blue >>> Yellow
Green >>>Green
johnrobholmes   1.21 GW
1.21 GW
Post by johnrobholmes » Sep 26 2010 3:27pm
Sounds like you hooked the throttle into the programmer cable. There is no white on the infineon throttle input (typically). Where did you get the controller?
oddjones   10 W
Post by oddjones » Nov 22 2010 2:25pm
Known combo for infineon controller to crystalyte 4 series anybody?
Home of the "bad wiring combo torture test" -- I test components until they break
oddjones   10 W
Post by oddjones » Nov 24 2010 2:39am
Nobody?
Does anybody know then if the wiring for Crystalite 4 series is the same as for Crystalite 5 series, as we have the wiring for infineon to 5304 on this thread already... (really don't want to dig out the fuses and spreadsheet again!)
oddjones   10 W
Post by oddjones » Nov 24 2010 5:38pm
ah shite ;-) Will post here when I've done it then...
shorza   1 kW
Post by shorza » Dec 03 2010 4:38am
Lyen 12 FET controller to Conhismotor 500w 48v rear wheel hub motor.
Halls
Lyen------CHM
Red-----Red
Black----Black
Blue-----Blue
Green-----Yellow
Yellow-----Green
Phase
Lyen------CHM
Blue-----Blue
Green-----Yellow
Yellow-----Green
daztay   1 mW
Post by daztay » Dec 25 2010 7:35pm
motor Crytalyte 504
controller Kelly KBS72101
Matching the colors just made it go backwards
After finding this thread I found this which was the closest to my config. So I matched the phases name (not pin numbers as there different)
HAL9000v2.0 wrote:Crystalyte 504 & Kelly KEB72331
X504 Kelly
Motor:
blue :arrow: A
green :arrow: B
yellow :arrow: C
Hall:
yellow :arrow: A(pin13)
blue :arrow: B(pin12)
green :arrow: C(pin11)
red :arrow: +5V(pin7)
black :arrow: GND(pin2 or 3 or 14 or bat- all is connected internaly)
Throttle:
black :arrow: +5V(pin7)
green :arrow: GND(pin2 or 3 or 14 or bat- all is connected internaly)
yellow :arrow: throtle signal (pin5)
red :arrow: not used
Motor - controller
Blue - Yellow(A)
Green - Green (B)
Yellow - Blue(C)
Halls
Motor - controller
Blue - green
Green - blue
Yellow - yellow
It seems to work.
Is there a number of combination that work and only one that works perfectly?
As the motor seems a bit gutless to what I thought it would be. As this is my first e-bike I have no reference of "guts" to motors.
I will reprogram the controller to see if I have limited the current to much or something.
edit
I have since found I had the battery current was set at 20%, so I will test it out latertoday
shorza   1 kW
Post by shorza » Dec 28 2010 11:46pm
daztay wrote: Is there a number of combination that work and only one that works perfectly?
edit
I would also like to know this. I am experiencing the 'no guts' feeling on my 48v kit. Although free-wheeling it can reach up to 60kph, once i sit and go for a ride, it is embarrassingly slow.
It very well could be my controller setup.
How did you know that your current was set at 20%?
daztay   1 mW
Post by daztay » Dec 29 2010 1:59am
shorza wrote: I would also like to know this. I am experiencing the 'no guts' feeling on my 48v kit. Although free-wheeling it can reach up to 60kph, once i sit and go for a ride, it is embarrassingly slow.
With my controller http://kellycontroller.com/KBShelp.php
I set the motor current to 20% as the controller is 100A and the motor is 20A so 20%
But I also set the battery to 20% where it should be 100%
I have not proved this as I have not had the time to take it for a good spin.
