Hi all,
I just converted an old road bike to electric, with a Bafang SWXH rear hub motor, a KT 12FET controller with KT-LCD3, and a LI-ion 36V 13Ah battery pack with 20A BMS, 8 magnet PAS sensor. I intend to use the bike with only PAS, in torque simulation mode.
I configured the parameters according to the manual and forum entries, and the whole thing works as expected with a thumb throttle. With the PAS there is a problem, that it constantly cuts off the power to the motor, then after a few pedal revs later it comes back. With P3 set to 1 (torque mode) it has a very nice smooth PAS action at all assist levels, until it cuts off.... With P3 on 0, I can almost use the bike on assist levels 1-3, but this is not the mode I'd prefer... on levels 4-5, when motor W passes like 400W, it cuts out also in this mode.
If I set it to 5 magnet PAS mode, it may be a little better, but not sure.... I also set C14 to low assistance, then it's still a little better, but not good.
Battery voltage is constant and high at about 39V at any loads, the LCD displays voltage exactly as I measure with a multimeter. The ASSIST text on the LCD flashes occasionally, and it somehow seems related to the cut-outs, but I'm not sure, sometimes it flashes, and still pushes. How is this supposed to work?
When it cuts out, the LCD stays on, ASSIST text flashes, motor W indicated as 0. If I push the thumb throttle in this state, it applies power nicely as if nothing happened.
Where should I start troubleshooting? Any ideas welcome.....
thanks!!
thanks!!
